Vibration
Old Apr 1, 2004 | 07:50 AM
ChuckZ28's Avatar
Unhappy Vibration
Well I have a pretty strong vibration while driving. It just started last week and its enough to shake the steering wheel. It only happens from 75mph at 2500 rpm and at 90 at 3000 rpm. I havent taken past 90 to see if it is still there but it seems its starting to fade around 90. It only does it at part throttle. Any ideas? My 96 S-10 has been doing the same thing for years but its not as violent.
Old Apr 2, 2004 | 05:38 PM
ChuckZ28's Avatar
actually it even does it as early as 65mph. Anyone have any ideas?
Old Apr 2, 2004 | 05:42 PM
78sixbanger's Avatar
Try gettin your tires re ballanced. I know that if they arent balanced right that your steering wheel will shake between a certain mph range
Old Apr 2, 2004 | 05:57 PM
cndctrdj's Avatar
try getting your tires balanced i did when i got my new tires and it made a word of difference.... what did you do the night before and what was the weather like when it started to happen
Old Apr 3, 2004 | 12:04 PM
ChuckZ28's Avatar
I dont remember what I was doing before it happened or how the weather was. Ill try rebalancing them. I just had new tires put on a couple months ago and I watched him balance them but I suppose a weight could have fell off somehow.
Old Apr 3, 2004 | 12:07 PM
Bersaglieri's Avatar
Sounds like Driveshaft like mine but my steering wheel doesnt shake...
-Dustin-
Old Apr 3, 2004 | 12:09 PM
cndctrdj's Avatar
a weight could have fallen off if ti was cold out and then got hot the expanding and contracting of the metals could have fallen or if you gat gotten some good grip hitting the breaks hard or hitting the gas hard your tire could have rotated on the rim it has happened to me before
Old Apr 3, 2004 | 12:15 PM
ChuckZ28's Avatar
Thanks Ill look into it.
Old Apr 3, 2004 | 12:38 PM
Pandamonkey's Avatar
-Dustin-
I've never experienced it but from what I have heard, the driveshaft vibration trouble is really only felt at high speeds.
Old Apr 3, 2004 | 12:43 PM
High speeds like 65 or above..mine starts at 75-80 but who's to say when it would start. I am just suggesting something.
-Dustin-
Old Apr 3, 2004 | 02:23 PM
CamaroSS30thAnn's Avatar
seems like everybody is leaning in the same direction i was..
wheel balance would shake the steering wheel left and right
driveshaft would just give u a vibration i dont c y it would shake the steering wheel
id lean toward the wheel balance since u said that u had them changed a few months ago
i have a wuick question.....would low tread on tires cause more road noise??
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
Apr 16, 2015 09:57 AM
