Vibrating at high speeds
Old Sep 15, 2003 | 07:04 PM
  #16
revtime's Avatar
No Problem,
I do agree with Scooby on some things.
Be safe first and foremost.
Always think before doing anything.
By the way the 1LE aluminum shaft cured my high speed vibration as well.
Old Sep 16, 2003 | 11:49 AM
  #17
varneyins's Avatar
Several possibilities: (1) Change to an aluminum driveshaft. I did and it vastly improved high speed vibrations - but didn't solve it.
(2) Could be tire balance, that is easy to do. Take it back to whomever sold you the tires and ask for a balance and rotate. (3) Could be your timing chain. I did 1 and 2 and then did 3 because of a front engine leak.......my timing chain was VERY loose and I put on a new Cloyes chain and gears, lowered high speed vibrations a bunch. (4) Could be rear gears if you've got 3.73s +.
The aluminum drive shaft is going to cost you a couple hundred and is worth it.....aluminum is balanced differently than iron shafts....iron shafts have balance weights welded on while aluminum is balanced by grinding away material.
BigWil
Mar 29, 2015 12:24 PM
Rde Bandit
Mar 21, 2015 10:17 PM
karnykamaro
Feb 2, 2015 01:37 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
mattszm6
Dec 14, 2014 07:09 AM
