Vette valve cover clearance
Old Feb 25, 2012 | 07:49 PM
tapoutjay44's Avatar
Guys, I have a 97 LT1 from a camaro z28 with Alum heads but during the rebuild I installed some roller rockers that I purchased from summit. Well now i ended up going with the vette accessory set up due to the ac pump clearance, and I got the valve covers for an even swap of my stock powdercoated ones. So now something is hitting and not letting the valve cover seat all the way down. I don't know if it's the top of the poly lock or the little fins inside of the cover. Anyone have any advice or experience with this?
Old Feb 25, 2012 | 09:41 PM
lt1-xjs's Avatar
Re: Vette valve cover clearance
Most likely the oil drip tabs, they need to be removed with the use of aftermarket rockers.
Old Feb 26, 2012 | 12:30 AM
Thank you kind sir, I'll have to try grinding them down.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
