Very rich after cam install - csv attached!
Old Mar 21, 2007 | 05:57 PM
BoozrCruzr's Avatar
Just installed a hotcam in my 94 z28. Car starts and runs OK, and will initially tach up OK, but it is running very rich...eyes wattering rich. Eventually starts missing and loading up then is hard to restart. I've only run the car about 5 mins since the install was finished and haven't tried driving it. I also noticed some smoke coming up from behind the intake today after I tried to restart it.
Car is currently running a mailorder tune from Madz28.
.csv is in the link. I'm open to ideas! HELP!
http://extremepsi.org/misc/test.csv
Old Mar 21, 2007 | 06:28 PM
LiENUS's Avatar
Switch to speed density and use VEMaster to fix it up.
Old Mar 21, 2007 | 09:07 PM
BoozrCruzr's Avatar
Anybody else find it odd that it is running 6.5% duty cycle at idle and the map is seeing 14.74 at idle? Not to mention injector pulse with is 10ms! Those numbers are almost 5 times what they were before I took the car apart.
Any ideas what would cause that? Is there something during re-assembly that would have screwed that up? A ground wire or something?
Old Mar 21, 2007 | 09:34 PM
BoozrCruzr's Avatar
Looks like I might have figured out my own problem. There is a braided grounding strap coming out of the harness by the coil that grounds to the body. This cable wasn't tightened down at all. I tightened it up and the car runs about 1000x times better. No logs yet, but I think that might have done it.
Hope this helps someone else!
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
