Very quick exhaust manifold ? which botl goes where?
Old Jul 22, 2004 | 05:07 PM
TexasTechTA's Avatar
on the very front stud that goes into the pass side manifold that holds the alt support bracket on as well. Is it a full stud with a nut half way, or is the the stud that is smooth on on part underneath the nut?
Which stud?
Basically how does that bracket go on I forget. thanks
Old Jul 22, 2004 | 05:28 PM
Re: Very quick exhaust manifold ? which botl goes where?
Pretty sure it is the one with the smooth part as you call it. One of those big spacers is used with it. There is no spacer used with the one with the nut in the middle.
Old Jul 22, 2004 | 05:34 PM
alright that makes sense thanks
Old Jul 22, 2004 | 06:02 PM
justa quick question si that bracket absolutely neccessary?
I already put the y pipe back on adn wopuld have to take it off again to get the botl back in and putt he sleeve/spacer in on the stud again?
Old Jul 22, 2004 | 06:45 PM
All I can say is there are some folks that don't use it.
Old Jul 22, 2004 | 07:34 PM
so is it okay is it gonna damage the alt? or make it unstable?
Old Jul 22, 2004 | 08:15 PM
25thBird's Avatar
Hasn't done it to me in over a month and a half...
Old Jul 22, 2004 | 10:48 PM
so is it okay to not run with the alt support rbacket that goes to the header?
Old Jul 22, 2004 | 10:55 PM
25thBird's Avatar
There was a thread on this before, and a bunch of guys we're not using it and had no problems. You should be fine as long as you have it supported by at least one of the front main brackets.
Old Jul 22, 2004 | 11:01 PM
great thanks, justa randon question when i was poutting the maifolds on the sensor ont he drivers side broke that I beleive is the block drain plug as well. what sensor is that and is it pricey?
69z-28
Jan 29, 2016 10:46 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
