Very Bad Problem With Car!!!!!!
Old Aug 17, 2005 | 10:07 PM
97formulakid's Avatar
Ok a few weeks ago I had a nitrous backfire on my car and at the time all I thought it did was blow my air filter to **** and descreen my MAF for me. At least this is all I noticed. Tonight for the first time since the accident I took the car out for a ride. Here is where the problems began........
OK I hadn't felt the power in a while so I figure what the hell. Had it in first and stepped on it, it pulled very hard up to around 3800 then it just fell on its face. I had the pedal to the floor and it wouldn't go anywhere. I was like WTF!!! So I let off the gas and put it in 2nd, take it up to around 2800 and floor it, it climbs to 4300 so I figured it was ok and then once again it just fell on its face. It did this several times at different RPM's so its not something that occurs at the same RPM. I can have the pedal to the floor and it just won't go anywhere. It's like I'm not even on the gas.
Just in case there is any confusion I was not on the spray, actually I am selling the whole kit to just get away from it and saving the money for a built motor.
Any suggestions would be helpful, I am really worried about it. Thanks
Old Aug 17, 2005 | 10:13 PM
Z95m6's Avatar
Re: Very Bad Problem With Car!!!!!!
Did you replace the MAF? if it blew the screen out i'm sure it damaged the wires in the MAF.
Old Aug 17, 2005 | 10:14 PM
The wires were not damaged, well at least what I could see. But no I did not replace the MAF.
Old Aug 17, 2005 | 10:31 PM
1racerdude's Avatar
Replace the maf and it will do better probably run like always.
Old Aug 18, 2005 | 06:50 PM
replaced the MAF and the car runs like it used to. Thanks for the help guys.
Old Aug 18, 2005 | 06:53 PM
1racerdude's Avatar
Anytime
Old Aug 18, 2005 | 08:18 PM
Z95m6's Avatar
Glad to hear it was a simple fix.
Noenav
Mar 1, 2019 07:38 AM
Britbilly
Jan 7, 2015 08:49 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
