Verdict is in, 0 compression #6 cylinder
Old Mar 31, 2006 | 07:33 PM
Javier97Z28's Avatar
Moderator
Read this thread for back story:
(cliff notes: lifters spun in bore after rockers came loose.. I think...)
http://web.camaross.com/forums/showthread.php?t=438130
Tested compression on #3, nice and healthy.
Compression on #6: 0 psi
Finger test on the plug hole of any cylinder blows your finger off the hole, #6 barely pushes out any air.
Not sure what the diagnosis is going to be, holed piston? Bent valve?
My buddy wants me to start pulling the engine w/ him tomorrow. I might, we'll see.
Old Mar 31, 2006 | 10:02 PM
1racerdude's Avatar
Re: Verdict is in, 0 compression #6 cylinder
On the original post I had a suspicion there was going to be something else ya was going to find.
Old Mar 31, 2006 | 10:22 PM
Kevin Blown 95 TA's Avatar
If it's coming out thru a valve you can crank it with the ign disabled and listen for it in the intake (with the TB open) or tailpipe. If it runs, you can put a vacuum gauge on there and see if a valve is staying open, although if you made a hole in a piston, that will cause a pulse too. I think you might have pounded a valve.
Old Mar 31, 2006 | 10:26 PM
Here's a happy piston picture from work. This was on a small engine.
Old Mar 31, 2006 | 10:32 PM
1racerdude's Avatar
Ya rattled that one,once to often.
Old Mar 31, 2006 | 11:07 PM
Josh'95Z28conv's Avatar
Put a cylinder leakdown tester on it like I said from day one. That way you can pressurize the cylinder, and listen to find out where the air is escaping.
Did you assemble the valvetrain with that bad cam? If the intake lobe is worn, it may not be letting any air in there.
Old Mar 31, 2006 | 11:38 PM
Moderator
Yah I threw two old lifters on it and popped the valvetrain back on. Cam isn't that worn out, it's got plenty of up and down travel as far as valvetrain movement is concerned.
There's so much metal in the oil chasing after this anymore is pointless.
Engine is coming out for teardown.
She will live once again.. in 355 glory.
Old Apr 1, 2006 | 12:43 AM
94 NO TOP Z's Avatar
Didn't get one of the rockers too tight did you?? That would bleed the compression off.
Old Apr 1, 2006 | 07:00 AM
1racerdude's Avatar
Old Apr 2, 2006 | 01:38 PM
Eric@Victory Racing's Avatar
Old Apr 2, 2006 | 03:00 PM
Moderator
Diagnosis:
#6 piston slapped the exhaust valve
Can you guys help me diagnosis this in anyway? I wouldn't have thought a rocker coming loose would have caused the exhaust valve to drop that far. Could it have been caused by an overrev due to my slipping tranny?
I'm confused now...
Anyways.. Eric, got your PM, if I a deal i have going on with a board member doesn't go through for some reason I'll contact ya, thanks!
Bent my #6 exhaust valve too.. DAMNIT.
Old Apr 3, 2006 | 08:10 PM
At 6000 rpm, a loose, lifter, pushrod, rocker will pound itself silly - it's all out of control at that point worse than just valve float. Just imagine it bouncing in there at 100 times a second all loosey-goosey and you can kind of get the picture. Say the lobe is coming around and the lifter isn't back down yet - it slams the lifter back up and that shudders thru the valve train and smacks the valve all at the wrong time - valve hits piston, everyone loses but the machine shop and the parts dealer.
Actually, we experiment with it at work and watch it through a strobe light or high speed camera. It's amazing what you see. Sometimes we destroy engines on purpose by running them flat out in a steel box until they explode or let out a death wail and screech to a halt. We only make up to 1000 cc, but it's still more fun than anyone should be allowed to have at work
Old Apr 4, 2006 | 07:20 AM
Moderator
Thanks Kevin, should I replace the two springs on that cylinder?
I'm not sure what happens to the strength of a spring when it goes to coil bind.
Old Apr 4, 2006 | 01:14 PM
The machine shop could probably test them out for you and see if they'r OK. Coil bind is bad for them, though cause there's no more give in the usual direction.
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
surreybrad
Sep 29, 2015 09:00 PM
jayblev95
Sep 26, 2015 09:44 PM
Daluchman1974
Sep 11, 2015 06:12 AM
