vented or unvented optispark?
Old Feb 28, 2004 | 01:15 PM
  #16
canbaufo's Avatar
Originally posted by rkussy
I wasn't going to change mine either when doing a cam install untill I learned that over 6000 rpm you need a heavier duty timing chain and I didn't want an electric water pump so the only option was to go to the vented opti so I could run a lt4 ex duty timing set.
So basically going this route is about $750 if I'm adding everything up right ...good lord. Every time I think about whether or not to do heads and cam while doing this rebuild there are a whole set of exponential costs associated with it. My stock opti seems to work fine and has 44K miles. Even though I'm rebuilding it kind of makes sense to me to keep the stock time chain and origninal opti vs chucking out nearly a thousand bucks for a conversion and new 95 opti.
It may be time to sell this car, this stuff is just too much and never ending
Old Feb 28, 2004 | 03:18 PM
  #17
ibanez6rg's Avatar
Whoa! I'm glad I didn't got your route!
Old Feb 28, 2004 | 04:50 PM
  #18
BPS's Avatar
BPS
canbaufo
ed timing set ~200
opti ~200
cover ~50
vacume hoses ~50
cost of conversion $500 less what you sell your stock opti for.
But unless you plan on reving >6K or are putting in a high lift cam - don't bother maybe replace the stock chain with a new one ~$60
What you may want to invest in is a keyed hub
but yes, it adds up fast
Old Feb 29, 2004 | 08:40 PM
  #19
canbaufo's Avatar
My estimate seems a little more realistic if you consider every little thing needed in that link and are using an LT1 Extreme duty set. .....and where are you guys getting optis for $200?!? I'm looking at Jegs right now and it says $277 for a 95-97 opti. I guess you have to specify that you have a 95+ opti when ordering a cam too hugh? Well...the estimate with the "ed" set sounds a little better. So maybe I could sell the stock opti for $100. BTW, what's an "ed" timing set (edelbrock?). Is this ed set good enough for 6,400 rpm? My car has demonstrated a high rpm miss, it comes and goes though. I have doubts that it's the opti and feel it may be a wire issue....have decided to go with Taylor OTVC wires. I swear though, it seems like with my luck maybe I better do the conversion now rather than getting it back together and then having the stocker fail....then having to cough up $400+ labor for a new 94
Is there any way to upgrade to a better stock type timing set? Like this Lunati set in Jegs for $110 ....would it maybe be 200 rpm better than stock?
Old Feb 29, 2004 | 08:49 PM
  #20
Spinner's Avatar
Parts from jason cromer
> 95' Front Cover 12552426- $67.00
> Vented Opti 1104032- $215.00
> Vented Opti electrical harness 12130319- $73.00
> Vented Opti vented vacuum harness 12555323- $13.00
> 1LE Elbow for vented opti 25147187- $48.50
$10 shipping total
Old Feb 29, 2004 | 08:51 PM
  #21
BPS's Avatar
BPS
I just bought an opti from dal - $196
extreme duty "ED" timing set $205 from jason Cromer
'95 timing cover and gasket $57 jason
vacume hoses/elect - ~$80 - you can fab your own
most cams come with the long pin required fror the "95+ opti
note: your stock cam will not work with a vented opti.
Old Feb 29, 2004 | 11:14 PM
  #22
canbaufo's Avatar
"I just bought an opti from dal - $196
vacume hoses/elect - ~$80 - you can fab your own"
Any links/phone numbers for these mysterious people? (I've heard of "dal" before ...lol)
Thanks....
I've decided to go ahead with the opti conversion and an aftermarket cam. I was just bitching when I said it's time to sell.....I can't get what I have in mods now much less what I'll have after the rebuild, I'm married to this freakin' thing...lol, at least I like it.
Old Mar 1, 2004 | 12:17 AM
  #23
BPS's Avatar
BPS
you don't know these guys! - boy have you ben missing out
Dal Slabaugh: 877-448-5451
email: lockitup@bright.net
VanDevere Buick/Pontiac/Olds Akron, OH
or
Jason Cromer: 877-726-8295 or 850-243-8826 (direct parts dept ph #)
email: gmparts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
Best prices for GM parts anywhere.
Old Mar 1, 2004 | 07:26 AM
  #24
Hawk350's Avatar
Hey guys....you dont have to change the opti when switching to a heavy duty timing set do you? I am planning an LT4 timing set when heads and cam...just wondering...
Old Mar 1, 2004 | 07:54 AM
  #25
I think this has been covered 3 or 4 times before, yes you must change to vented to run the LT4 set.
Old Mar 1, 2004 | 10:12 AM
  #26
......Any links/phone numbers for these mysterious people? (I've heard of "dal" before ...lol)
You've been on the board for 3 years.... have over 1,500 posts.... and you've never heard of these people, an Extreme Duty timing set, or a vented Opti for ~$200........ ????????????
Old Mar 1, 2004 | 02:20 PM
  #27
ram air camaro's Avatar
how about the delteq? i would like to go that route if it's not to expensive.
Old Mar 2, 2004 | 09:50 PM
  #28
canbaufo's Avatar
I've only put 7,000 miles on my car since I've been on this board....so I have had no need to know these things. I guess until I need something I don't even bother finding out about it ....lol. Yes, I had heard of "dal" and an extreme duty set ...just hadn't seen it as "ed". No, didn't know about Jason though. Thanks for the info though Bill.
Kind of seems like I should do it because I'd be upset later on if I had to replace the opti and then decide to do the E.D. and opti ......or .....pay more to just replace the crappy unvented one with another one, and be stuck with a lower duty timing set. The PITA labor to do it then vs now while it's all apart is really the big thing.....especially the way my blower blocks the opti. Also, I can actually get money out of my opti now since it works. Just seems like common sense to do the upgrade.....arggh, more money to spend though. Question: Why is the vented opti actually cheaper?
Old Mar 2, 2004 | 09:56 PM
  #29
BPS's Avatar
BPS
Likely a supply and demand issue - lots more demand for the unvented one.
Old Mar 3, 2004 | 12:41 AM
  #30
LTCC?
WHATS AN LTCC? OH I ALSO TALKED TO THE DELTEQ PEOPLE AND GOT SOME GOOD INFO ONTHER SYSTEM THEY TOLD ME THAT IT DOES NOT ELIMANATE THE OPTI COMPLETYLY ONLY THE HIGH OUTPUT SIDE AND THE LOW OUTPUT OR SOMETHING LIKE THAT IS STILL BEING USED WITH THE OLD OPTI YOU FIGURE! NOT A GOOD IDEA TO ME .
