Vented opti lines... where do they go?
Old Jul 9, 2003 | 08:23 PM
Jesse_Boyer's Avatar
Can anyone tell me where the vent lines go exactly? ie, the line that runs from the metal hose barb on the opti goes "xxxx" and the line from the plastic hose barb goes "zzzz."
I don't have the GM lines so i'm going to have to construct my own.
Jesse
Old Jul 9, 2003 | 08:29 PM
wicked_95z's Avatar
The vaccum line with the 90* elbow goes on the top of the intake elbow and the other one goes into the drivers side of the intake. Mid-way down the side on a small fitting towards the bottom. I dont think it matters where they go on the opti-spark. Dont remember either
Old Jul 9, 2003 | 08:31 PM
ok, so one of the lines draws air out of the intake tube and the other uses vacuum to pull air out of the opti and into the intake, correct?
Old Jul 9, 2003 | 08:45 PM
wicked_95z's Avatar
Actually I think they are two seperate lines. One provides a vaccum to keep moisture out of the cap and rotor section and the other does the same but for the optical sensor side.
Old Jul 9, 2003 | 08:47 PM
oh. So which port from the opti goes to the intake manifold and which goes to the intake elbow?
Old Jul 9, 2003 | 10:59 PM
One hose goes to the intake manifold for vacuum. The other hose goes to the intake elbow for clean air supply. This constantly draws clean air through the opti to help reduce moisture and ozone contamination.
Drawing
Old Jul 10, 2003 | 02:56 PM
wicked_95z's Avatar
Thanks Shoebox. I figured one of the wise men would jump in and clear things up before too long
Old Jul 10, 2003 | 07:07 PM
nice work shoebox. well done
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
colts0455
Sep 27, 2015 01:07 PM
tdigger9899
Sep 7, 2015 10:56 AM
