vented opti
Old May 30, 2003 | 12:02 AM
FLIPPINZ28's Avatar
vented opti
okay here is the deal i hear people talking about a vented opti what is the diffrence between the vented one and the one i have which is stock i have a 93 z28 with the engine getting rebuilt so now will be the time to do it . will it help me in any way also can i do this to a 93 what are the benefits with this thanks kenny
Old May 30, 2003 | 12:17 AM
chasmanz28's Avatar
Re: vented opti
vented, the changes were basically made to improve the opti by adding a ventilation system that is connected to the air intake. This draws air through the distributor to eliminate moisture buildup in the optical mechanism. With the low distributor mounting, plus the water pump being directly overhead, there was a tendency for moisture and coolant to seep into the distributor leading to the infamous "optispark" problems. non vented opti doesnt have that ventilation
Old May 30, 2003 | 02:03 AM
FLIPPINZ28's Avatar
can i put one on my 93 z28 also where can i get one for the best price plus quility
Old May 30, 2003 | 08:14 AM
Phatcaprice's Avatar
For the conversion, you'll need the following:
1. Vented opti (94-96 b-bodys, 95-96 f-bodys)
2. Timing cover to accomodate. (Big hole in the center, but not 96' type.) (94-95 b-bodys, 95 f-bodys) Your cover has a small hole in the center.
3. Camshaft with pilot hole and long dowl pin for opti driveshaft. (94-96 b-bodys, 95-96 f-bodys) Better yet, get a hot cam or comp305 or 306!
4. Cam gear with large center hole. (94-96 b-bodys, 95-96 f-bodys)
5. Hoses to connect the opti to the manifold and intake duct.
There may be more, but that's basics. GL!
Old May 30, 2003 | 08:16 AM
chasmanz28's Avatar
just tell the guys who are rebuilding your motor what you want done with the opti, they should know the parts you need
Old May 30, 2003 | 08:27 AM
96ZRDR's Avatar
Do it right the first time, you also might want to consider a elec WP, but that would require a little different set-up. I have all the part numbers for that. Email me if you need them or just search the board.
LT4 Heavy Duty Timing Gears/Chain for that bad boy.
Elec harness 12130319 (you will have to modify the male side of the connector slightly, you will know what I mean)
Vac harness 12555323
Vac fitting 14082470
OPTI (95 Vented) 1104032
Timing Cover (95) 12552426
and always make sure the cam dowel length is just right.
Good Luck.
Old May 30, 2003 | 08:28 AM
speedmiser's Avatar
Jason quoted me $350 for the complete vented opti conversion, 'bout 2 days ago.
Jason Cromer 877-726-8295
Old May 30, 2003 | 08:31 AM
chasmanz28's Avatar
yeah flippin if you going to buy that opti go with jason hes the cheapest around
Old May 30, 2003 | 10:59 AM
SweetZRag's Avatar
Just to add my $.02, the vented Opti also serves another important purpose. The venting is to clear out the ionized air that results from the high voltage arcing between the rotor and the cap. If not cleared out, it can contribute to faster corrosion/breakdown of the other parts in the distributor.
If you have ever stood near the railroad tracks of an electric train and smelled that smell as the train approaches, you know the smell of ozone (ionized air) caused by arcing from the trains contacts. You also smell it after a lightening storm. Smells good but bad for rubber/plastic parts and seals.
Old May 30, 2003 | 03:34 PM
FLIPPINZ28's Avatar
thanks everybody
Old May 30, 2003 | 05:51 PM
limige's Avatar
just another quick question with the vented opti swap.
i already have my opti and will get a timing cover shortly.
if i goto a local gm dealer, how much will the misc. stuff cost me?
you know the vacuum stuff and wiring harness.
thanks,
mike
Old May 31, 2003 | 03:17 AM
limige's Avatar
ttt
Old Jun 1, 2003 | 03:19 PM
eyeoutthere's Avatar
thanks,
mike
a LOT more than if you bought them from Jason. At least $600.
Edit:
Just the wiring harness and VAC stuff will cost you $120-150 from a dealer.
Jason can get them to you $70-80 (I'm guessing)
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
colts0455
Sep 27, 2015 01:07 PM
tdigger9899
Sep 7, 2015 10:56 AM
