various cam and driving questions
Im putting a cam in my 95 Z28.. thing is it has 80 thousand well cared for miles.. I want a huge cam but i dont want heads..only doing a cam and then im done.. i have the factory LT4 1.6 RRs already installed on my car. Already have one im just going bigger. Which cam is the best one for accelleration... I want crazy horse power and nutso torque.Which is the cam to go with???.. not concerned with gas mileage at the moment.. I will when its installed but its not a concern right now... Second question- my car feels like its lost power.. and it has.. i lined up with a stock Z with an intake. i think it was a 1996.. and he kept up even with me and i mean dead even... I have K&N FIPK and MAC headers and Hooker cat back and not cats, tb bypass.., 160 thermo.. automatic fan switch, 1.6 RR, ported MAF, Air foil, !air, have yet to delete EGR(does it matter if i dont?), Feed tube block plate, MSD 8.5 wires(6 months old) New MGK plugs and MSd blaster coil W/ accel 300+ ign and LT1 edit... What is wrong with my car.. it all of a sudden lost power... WHAT GOING ON???? 3RD?- Im sitting around my house with nothing to do... Is there anything i can do to my car that doesnt cost anymoney?? Like for instance Cleaning the TB(sprying the stuff in it), or cleaning sumthing??????
If you want to really know what is going on, get a scanner/datalogger (ie. TTS Datamaster), learn how to use it and interpret the readings. You will then be in a perfect position to get any problems worked out.
Originally posted by CoUnTryMuZiCZ28
sent you an email... also what do you think a good cam for me is? i was thinking LT4 hot cam... How much difference is the cc 306?
There are so many combinations that you could use, sometimes it is just a matter of personal preference.
The xe224/230 or cc305. Both should give you a 20-30rwhp gain with a dyno tune. Pcmforless has luck with a pretty accurate mail tune. You are def. going to need springs,locks, retainers, timing chain and gears. Pushrods and lifters wouldn't be a bad idea either. The driveability wouldn't be too bad with them. Check sig's see peoples dyno numbers and times. You'll find something you want.
