Valvetrain interference problem.
Old Nov 10, 2004 | 01:07 PM
sssalah's Avatar
I had an interference problem between some of the exhaust retainers and the self guiding pieces of the roller rockers. The springs were cc 986 with 10 degree locks, rockers are LT4 and valves are Federal Mogul.
I changed the springs to crane 308 and the problem is still there. So now I think it’s the valves, I think the locks groove is placed higher on these valves. These are supposed to be stock replacement small block valves, did they come with different groove height, am I better of replacing the locks with offset ones like -0.05” installed height.
Old Nov 10, 2004 | 04:13 PM
96ZRDR's Avatar
Re: Valvetrain interference problem.
I have read somewhere that (GM) LT4 roller rockers would only clear up to .550 lift. The XE 230/236 cam has .555 lift at the exhaust, that definetely would explain your problem.
Old Nov 10, 2004 | 10:54 PM
sssalah's Avatar
This issue is with my B-car, it has a crane 227 cam with 0.553 exhaust lift. The LT4 rockers are actually good for 0.575 and that is limited by the slot not the tip. These same rocker were working fine on my F-car before I changed to nsa promags.
I want to make sure what I need before tearing up the motor.
Old Nov 11, 2004 | 01:28 AM
hvyss's Avatar
I had a simular problem with my 190cc AFR heads and the GM rollers. The rocker body rode on the retainer and not the valve. Causing undue wear on the rocker. Come to find out the valves were too short by .010. Had to use the narrow body CC Pro Mags and no further problems. I hope this helps.
HVY SS
Old Nov 11, 2004 | 02:30 AM
sssalah's Avatar
HVY SS
Thanks it did help, better to change the rockers then to tear up the motor. Are these self aligning rockers?
Old Nov 11, 2004 | 01:03 PM
hvyss's Avatar
Yes. When you order them make sure to tell them you want self alining rockers. Summit and Jegs both stock them.
HVY SS
MDZ28
Sep 7, 2015 09:16 PM
War Engine
Aug 21, 2015 05:28 AM
Aug 5, 2015 08:35 AM
88IROC_Z
Jul 22, 2015 11:38 PM
Jul 17, 2015 02:47 PM
