Valvetrain Faqs
Old Oct 19, 2004 | 05:00 PM
S8ER95Z's Avatar
Valvetrain Faqs
Can we get a sticky with different springs and what they will work with?
I see a lot of post concerning this and the info has been posted numerious times..but its spread all over the place!!
I can start off if it helps... or someone else can contribute/correct me.
I have a CC306 and Im using combination motorsports EX-612s. Good for .600 lift and fits on stock heads with no machining.
Old Oct 19, 2004 | 05:01 PM
dmoor88's Avatar
Re: Valvetrain Faqs
how long have you been running your 612's with the 306?
Old Oct 19, 2004 | 05:03 PM
S8ER95Z's Avatar
Re: Valvetrain Faqs
I have 1,000 miles on them so far. About a month total right now. I did a heat cycle break in, taking it easy on them.. currently shifting on the stock set 5700rpm but will be moving up to 6300rpm this weekend.
Old Oct 19, 2004 | 05:04 PM
Z95m6's Avatar
Re: Valvetrain Faqs
Why do we need a thread about what spring work with what cam? If you can do some simple math you can figure it out yourself.
Old Oct 19, 2004 | 05:05 PM
dmoor88's Avatar
Re: Valvetrain Faqs
not bad at all. what's your total lift? I plan on running the same springs with the 227/233 cam.
I know Crane also has a single coil spring that fits stock seats.
Old Oct 19, 2004 | 05:18 PM
S8ER95Z's Avatar
Re: Valvetrain Faqs
Z95, I dunno if you looked around but there are a lot of threads asking.. It would make everyones lives easier to have a FAQ. I just went thru this mess and it took hours of searching to find the right springs. Congrats if simple math can help you pick the springs, but does math tell you if they fit your heads? If they need machining? Etc?? Just trying to help others out.
Old Oct 19, 2004 | 06:01 PM
Z95m6's Avatar
Re: Valvetrain Faqs
well i think it would be easier to post how to select springs then what springs work with what cam.
HectorM52
Jul 30, 2017 11:46 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
formula79
Apr 1, 2003 05:26 PM
treyZ28
Mar 23, 2003 01:27 PM
JasonD
Jul 15, 2002 02:17 PM
