Which valves for trickflow 62CC heads
Old Dec 11, 2006 | 07:36 PM
TransAm396's Avatar
Which ones should I get manley or ferrea? and where Can I get them(part numbers?)
I need 2.02 and 1.600 but theres so many different sizes I dont know which ones to get.
Old Dec 11, 2006 | 07:46 PM
Spinner's Avatar
Call any of the board vendors, I'm sure they could point you in the right direction
Old Dec 11, 2006 | 07:48 PM
TransAm396's Avatar
that didnt answer any of my questions. BTW this is my 2,000th post.
Old Dec 11, 2006 | 07:49 PM
TransAm396's Avatar
Oh, how long do the valves have to be also?
Old Dec 11, 2006 | 08:26 PM
SStrokerAce's Avatar
2.055/1.60 wuldbe my choice if you are porting them
TransAm396's Avatar
well, im not going to port them this year..I just traded my LE2's for them, I plan on getting them ported next year when I want to make more power. The only thing is I dont know where to get the exact valve to fit the head. I see so many different lenghts and thickness's and was wondering if someone had a part number for a good set of valves like the ferreas.
Old Dec 11, 2006 | 08:52 PM
MachinistOne's Avatar
Ferrea F6114 2.055" intake/ F6104 1.60" exhaust - those are 5.010" length which should work out just fine for installed heights. If you need a 2.02" - the part number is F6150
Trick flow seats are shot for 2.02" out of the box...
Old Dec 13, 2006 | 10:29 PM
TransAm396's Avatar
I just found out that the exhaust valve on the TFS head is slightly longer 4.98 as opposed to the normal 4.96(the intake is 4.96. But I guess ferrea makes a valve ONLY for this trickflow head and its a dollor cheaper than the normal ferrea valve. in summit the part number is tfs-51400212
Old Dec 14, 2006 | 05:41 AM
Projectz28's Avatar
Moderator
I needed a longer valve also but I have 2.08/1.60 in my trick flows 5.060 length...
http://store.summitracing.com/partde...0&autoview=sku
Old Dec 14, 2006 | 05:45 AM
TransAm396's Avatar
why so long?
Old Dec 14, 2006 | 05:56 AM
Projectz28's Avatar
Moderator
.700" lift solid roller
Old Dec 14, 2006 | 11:17 AM
TransAm396's Avatar
gotcha
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
