Which valves for trickflow 62CC heads
Which ones should I get manley or ferrea? and where Can I get them(part numbers?)
I need 2.02 and 1.600 but theres so many different sizes I dont know which ones to get.
well, im not going to port them this year..I just traded my LE2's for them, I plan on getting them ported next year when I want to make more power. The only thing is I dont know where to get the exact valve to fit the head. I see so many different lenghts and thickness's and was wondering if someone had a part number for a good set of valves like the ferreas.
Ferrea F6114 2.055" intake/ F6104 1.60" exhaust - those are 5.010" length which should work out just fine for installed heights. If you need a 2.02" - the part number is F6150
Trick flow seats are shot for 2.02" out of the box...
I just found out that the exhaust valve on the TFS head is slightly longer 4.98 as opposed to the normal 4.96(the intake is 4.96. But I guess ferrea makes a valve ONLY for this trickflow head and its a dollor cheaper than the normal ferrea valve. in summit the part number is tfs-51400212
I needed a longer valve also but I have 2.08/1.60 in my trick flows 5.060 length...
http://store.summitracing.com/partde...0&autoview=sku
oldschool
Feb 9, 2016 09:21 PM
