Valves out of wack?
Old Aug 15, 2003 | 09:05 PM
91RSLT1's Avatar
Valves out of wack?
My car has a low rpm stumble and backfire. I am going to reset the valves this weekend. Is it possible that the valves can cause the stumble/backfire on low rpms only? The car SEEMS fine in the upper rpms, without any stumble/backfire. The only other culprits I can imagine are the MAF, bad injector(s), or a vacum leak. The car has two day old O2's, plugs (NGK tr55), new wires (delcos), opti, and coil. The car also has hard starts, but only when it is hot, valves? Please help this car is p***ing me off. Thanks.
Old Aug 15, 2003 | 10:20 PM
It is more likely that incorrect preload would have symptoms you would feel at any rpm. Usually more noticeable at low rpms.
Old Aug 16, 2003 | 10:25 AM
91RSLT1's Avatar
Would the incorrect preload cause the hard starts? Thanks.
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
