valves i think
Old Aug 31, 2004 | 02:58 AM
cndctrdj's Avatar
valves i think
well recently i have noticed a tapping sound in my engine
it is a light tapping only when i accellorate
i thought maybee it was an exhaust leak but it doesn't do it unless thier is a load on the engine
it doesn't seem to effect my power too much but it does kill a little bit of it
im having my mechanic check it out on thursday
but i wanted you guys/gals opinions first you seem to know more than anyone else
any other info needed just ask ill gladly tell you
o ya do these rockers need adjustment at any point or do they pretty much stay where they are supposed to be?
Old Aug 31, 2004 | 03:07 PM
"White Knight"'s Avatar
Re: valves i think
Hey man when you figure this problem out hit me up. I have the exact same thing. It is worse when the engine is just started up. I have no idea what it is-but i can garentee it's in the vlavetrain. I just didn't want to waste my time and money on something i will probably change anyway. I have had it for ever and is very annoying at light throttle...........guess that's why i drive WOT all the time or at least that is my excuse.
Old Aug 31, 2004 | 03:23 PM
BUBBA's Avatar
Re: valves i think
Well, you certainly need to find out what's making the sound and whatever you do if your oil pressure takes a dive, turn it off NOW.
You shouldn't have to make any adjustments to hydraulic lifters once they are lashed.
But if it is coming from the valve train it could be a collapsed lifter. That would certainly make a little noise and suck some power out.
As long as you're in there, might as well go with some 1.6RRs and some springs (if you don't already have them). JMHO
Old Aug 31, 2004 | 10:07 PM
cndctrdj's Avatar
Re: valves i think
if thie ris a problem with it i was going to get the 1.7s and a few other nice parts
Old Sep 3, 2004 | 12:14 AM
cndctrdj's Avatar
Re: valves i think
it is just an exhaust leak
my exhaust manifold gasket leaked it has 162k on it
thats pretty good
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
