Valves and heads ??'s (pics inside)
Old Oct 3, 2007 | 02:11 PM
30696bird's Avatar
I took my heads apart and it looks like some cylinders are running rich and some are running lean but I figured I'd ask what y'all think.
Here is the whole set (not in any order)
As you can tell I had some BAD exhaust leaks. I'm sure that's why the valves are so discolored.
Here is a closer look of some valves.
If you look you can see some buildup on the intake valves.
And here are some of the ports. The intake looks kinda oily to me.....is this normal or do I have a problem I need to address with the new heads?
Old Oct 3, 2007 | 03:48 PM
Sweetred95ta's Avatar
Looks like some of your valve seals were leaking.
Old Oct 3, 2007 | 04:12 PM
30696bird's Avatar
That's what I was thinking. I hope it's faster (and quicker )when I put the new heads on it and it's not leaking oil in the cylinders. It only ran a best of 8.1 @ 87MPH in the 1/8th.
Old Oct 3, 2007 | 07:57 PM
MachinistOne's Avatar
How many miles are on the motor?
Old Oct 4, 2007 | 06:51 AM
30696bird's Avatar
~15,000 I probably messed the seals up when I installed the springs. The springs that the machine shop put on were pac springs and I had never heard of them so I assumes they were not good quality....OOPS! I changed them to the 26918's. I had to take the valve guides out to put the seats on the head. Those heads were completely gone through and cleaned when the engine was built ~15K ago. The heads were suppose to be ported but they don't look very ported to me.
Old Oct 4, 2007 | 06:53 AM
30696bird's Avatar
Also, I'm buying new pacesetters because my Jethots are TRASHED.
Old Oct 4, 2007 | 08:29 AM
What?
Old Oct 4, 2007 | 09:29 AM
30696bird's Avatar
Originally Posted by Sweetred95ta
What?
Seals I meant....lol
Old Oct 4, 2007 | 09:44 AM
What kind of seals did you use? I recommend not using a teflon seal and make sure it pushes down tight over top of the guide.
Old Oct 4, 2007 | 09:47 AM
30696bird's Avatar
I'm not sure, the machine shop put them on the first time. But thanks for the advice on the teflon seals. I won't use them. Do you have a suggestion?
Old Oct 4, 2007 | 08:02 PM
You have a lot of oil buildup on the valves for 15k miles - and it does not look like seals were the cause - maybe an intake leak.
Viton metal clad seals are the ones to use - any decent machine shop should have them in stock.
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Feb 28, 2015 12:02 PM
nikolt1
Feb 27, 2015 09:10 PM
BIGCOWL-IMP
Feb 7, 2015 06:10 PM
omarECD
Aug 19, 2002 07:28 AM
