valve train...
Old Feb 20, 2006 | 09:23 AM
95_z28_4_Ivan's Avatar
valve train...
Hey guys, I'm getting ready to place my order thru jegs, just wanna to check in with you pros to get any last comments about the products I'm about to purchase. oh yeah do I also have to buy "spring locators" or "stem Locks" or are those optionals?? I'm also not sure if I picked the right springs.
Thanks in advanced.
This is what I have in my cart so far:
249-7608-16 Chevy Magnum P.R. 265-400 w/OEM Hydraulic Roller CAM, DIA 5/16'', Length 7.200
$109.99
249-4808-8 Chevy 265-400 Flat, 5/16'' (guide plates)
$19.99
249-1305-16 SB-Chevy 1.6 Ratio, 7/16'' Stud, 16/pkg, (B)(C)
$259.99
249-4503-16 Magnum Rocker Stud
$49.99
249-925-16 1.510'' Dual-Spring with Damper (920/975) Valve Springs
$122.99
249-741-16 Super lock retainer Lock Angle: 10° Valve Stem Size:
ALL Valve Spring Diameter: 1.500'' - 1.550''
$52.99
Old Feb 20, 2006 | 02:13 PM
sssalah's Avatar
Re: valve train...
These valve springs are huge, you may have interferance issues and they're overkill for your cam, look into the beehive 26918 spring from comp with the required retainers, locks and seats. Seats are not optional with aluminium heads. Get the GMPP guideplates instead of aftermarket for better rocker alignment.
Old Feb 20, 2006 | 02:33 PM
Bersaglieri's Avatar
Re: valve train...
I'd do Comp Hi tech 5/16" 7.200 pushrods for a bit more, instead of magnums. ARP 7/16" Studs I believe are $29.99 through Summit. Definately use the GMPP guideplates instead of whatever you have there. Does Jegs have free shipping, just wondering caues Summit does if thats another factor. You might consider the Crane LT1 spring kit for $140. Its got all the little parts included.
-Dustin-
Old Feb 20, 2006 | 04:23 PM
MyShibbyZ28's Avatar
Re: valve train...
I don't see 10* locks to go with those 10* retainers. So YES you NEED valve stem locks.
You got
Camshaft
Guideplates
Roller Rockers
Studs
Springs
10* Retainers
You need
10* valve stem locks
You should concider
Valve stem seals
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
