valve stem seals for aftermarket valves?
Old Dec 20, 2003 | 07:13 PM
aram's Avatar
I want to change the valve stem seals on my heads which are ported stock lt1 heads by McKenzie Cyl. heads.. I didn't buy the heads they came with another car I bought.
How can I check to find out what kind of valve stems seals I need? I am pretty sure the valves are aftermarket slightly larger than stock. Would Fel-Pro seals be fine to use?
Old Dec 21, 2003 | 05:27 AM
rskrause's Avatar
Moderator
Unless you have some really odd valves the diameter of the stem should be the standard SBC (11/32").
Rich Krause
Old Dec 21, 2003 | 09:40 PM
aram's Avatar
Thanks.. I picked up some felpro viton valve stem seals for intake/exhaust.. are these good seals? I also heard that the valves could possibly be machined for a different type of seal than is used in stock applications?
Old Dec 22, 2003 | 04:07 AM
rskrause's Avatar
Moderator
What can be machined is the top of the valve guide, if you want to use a different type/diameter of seal or if you need more clearance for the bottom of the retainer to the top of the seal (high lift cam/short valve). The FelPro viton seals are excellent. Use them.
Rich Krause
Old Dec 22, 2003 | 06:11 PM
aram's Avatar
Thumbs up
Thanks!
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
blac94Z
Nov 28, 2014 01:53 PM
TA Jack
Sep 3, 2002 07:52 PM
