lose hp on open headers or no?
Old Dec 22, 2003 | 12:43 PM
glennxx1's Avatar
thoght backpressure was a must on low mod (bolt on) cars
Old Dec 22, 2003 | 12:59 PM
Spinner's Avatar
Sure isnt.... but you'll make more torque with a good catback or duals setup.
Old Dec 22, 2003 | 01:03 PM
Camaro_Maniac63's Avatar
Backpressure is necessary for small displacement engines. In our cases, the less backpressure, the better. You will gain quite a bit on the top end that most people usually start thinking they lost some bottom end power. Good luck.
Old Dec 22, 2003 | 01:14 PM
FacelessZ's Avatar
I'm running open TPiS LT's right now and I'm loving it! Gotta go get a a y pipe made some time today or tomorrow though...
Old Dec 22, 2003 | 01:22 PM
Antz97ZNJ's Avatar
heard some good numbers from open headers..Proven by back to back dyno pulls w/ and without open
Old Dec 22, 2003 | 02:15 PM
Grease's Avatar
At the dyno shop I go to they had a bolt-on LS1 Camaro loose hp by going to open headers. Of course they gained it back when they put the y-pipe back on, this was with LTs headers too. I don't remember the exact figures but the car was making around 340rwhp. Sometimes truth is stranger than friction.
Old Dec 22, 2003 | 03:08 PM
leadfoot94's Avatar
I know when I open my Cut-out's I tend to lose some low end acceleration/torque because of the loss of back-pressure, but it definitely pulls stronger at higher RPM's.
Old Dec 22, 2003 | 05:19 PM
Cmr0z28's Avatar
Old Dec 22, 2003 | 05:41 PM
z28marine's Avatar
with my cutout on, it feels like all the low end torque is gone, and its sluggish at low RPM's...but one i hit about 3-3 1/2 grand, the car just takes off
Old Dec 22, 2003 | 05:57 PM
Camaro_Guru16NY's Avatar
I think that its more of a trade off on lower HP cars. You may loose a little on the bottom end but once you get into the upper Rpms you gain a little more due to better flow. But you gotta figure that even though you may loose a little on the bottom that it sounds so damn gooooooooood
Later,
-JOhn
Old Dec 22, 2003 | 06:08 PM
Buttercup's Avatar
The only thing that may reduce peak power with open headers is possible false knock and also any fueling problems you may encounter if reversion hits the O2 sensors.
Old Dec 22, 2003 | 06:49 PM
Soccerbum21's Avatar
backpressure is a myth. YOU DONT NEED ANY..period
the key to a good exhaust system is how it flows in a constant diameter pipe. The reason people feel like they lose horsepower is that the higher RPM is so much better
here is a quote from sport compact car magazine's website
"To produce the most power, an exhaust should have the least amount of restriction to the exhaust flow. Restriction hampers the burned exhaust gases from exiting your engine, causing some charge dilution with the incoming fresh fuel/air mixture. (In other words, exhaust left in the cylinder is mixed with the fresh intake charge.) This causes a loss of power. With greater restriction, back pressure is generated, making the engine work harder to pump the exhaust out of the cylinders. This is one source of pumping losses."
the rest of the article can be read at
Article Link
there, read up. It is true from import to domestic. 1.3L to 8L motors.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jasonduaine
Apr 1, 2015 08:09 PM
rckrzy1
Aug 14, 2002 10:00 AM
