Which valve stem seals ?
Old Feb 19, 2008 | 03:38 PM
a4z28's Avatar
I need some help with which valve stem seals to go with i have the crane 10308 spring kit and the heads are stock and on the motor . Which valve stem seals are good ones to go with and does anyone have a part #s. thank you
Old Feb 19, 2008 | 03:46 PM
black95maro's Avatar
comp 503-16s and i have the same spring kit
by the way, what cam are you running?
Old Feb 19, 2008 | 04:05 PM
guest74777's Avatar
Guest
i just run fel-pro oem replacements have always worked good for me
Old Feb 19, 2008 | 06:50 PM
a4z28's Avatar
gm 847 cam with 1.6 rockers
Old Feb 19, 2008 | 09:53 PM
what are the specs? i'm cam shopping now and looking at the cc305 but not positive yet...
Old Feb 19, 2008 | 09:58 PM
porksoda's Avatar
But the car in your sig is a V6? On any note the 847 is MASSIVE compared to the 305.
Old Feb 20, 2008 | 12:06 AM
Steve in Seattle's Avatar
Post
what he said. My 847 is WAY larger than any cam I'd stick in a 350 without serious head work and the will to shift at 7000.
Old Nov 18, 2008 | 04:23 PM
ss.slp.ls1's Avatar
Why does Summit say that machine work is required?
Anyone else have an opinion on the felpro seals? Will they work with the Crane dual valve spring kit?
Thanks for the help.
Old Nov 18, 2008 | 05:08 PM
Kevin97ss's Avatar
I prefer to use factory or OEM replacement seals if it will see street duty. I know the factory seals will work just fine with those springs.
Old Nov 18, 2008 | 05:22 PM
ss.slp.ls1's Avatar
Thanks. Is there a reason for your preference?
Old Nov 18, 2008 | 05:46 PM
Kevin97ss's Avatar
Simply, because they will last. Teflon or any other "trick" seals that may be available were never designed for daily driving.
Old Nov 18, 2008 | 06:39 PM
Don 97 SS's Avatar
I used a set of Victor Reinz (Dana) valves stem seals and they looked well made and have performed well.
94Form
Jul 17, 2015 10:56 PM
GT what?
Jul 14, 2015 10:17 PM
camaro02DK
Jul 5, 2015 09:24 AM
KamikaZ28
May 28, 2015 12:45 AM
