Valve Springs will work?
Old Jul 21, 2009 | 10:08 PM
fastlt1camaro's Avatar
Question Valve Springs will work?
I have a 1994 z28 camaro I am installing cc306 cam I was wondering if sbc valve springs would work? Thanks.
Old Jul 24, 2009 | 09:17 AM
Diamhea's Avatar
I used Patriot "Gold Xtreme" springs for my 306 install. Most people recommend Comp Cams' springs as a minimum when installing this cam..
Old Jul 26, 2009 | 10:38 AM
NightTrain66's Avatar
springs that basically fit a SB Chevy will fit an LT1 also but you need to make sure the springs that you get have the seat pressure, open pressure, coil bind clearance and are made of a quality wire so they will work with your cam and RPM the engine will see.
The BEST set uip will be the Patriot Gold Extreme springs. They are springs, retainers, locks, locators and seals all in one kit. They are $275 plus $10 shipping thru Patriot.
Lloyd Elliott
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
