Valve springs on trick flow heads good with 224/230 cam?
Old Apr 26, 2007 | 06:37 PM
  #16
RealQuick's Avatar
Originally Posted by tagz
Talked to compcams. They agreed, spring pressure if a crucial factor for boosted engines. Not that i didn't believe you, i found another post that were arguing whether or not it mattered.
They recommended their 977-16s. 150 on the seat pressure and 441 on the spring rate.
I believe my AFR's have the big block beehives setup @ 150 on the seat (set up by LE).
Old Apr 27, 2007 | 06:46 AM
  #17
89385formula's Avatar
I believe you are talking about the 26120 beehives, these require longer valves to have the right spring pressures/installed height. Thats the information I got when setting up my valvetrain.
Old Apr 27, 2007 | 09:08 AM
  #18
RealQuick's Avatar
Yup. Here are the finished specs on my AFR210's:
Springs (Comp # 29120) set up at 1.880 and have 155 lbs on the seat
65 cc chambers
214 cc intake port
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
