Valve springs kit?Retainer and locks included???
Old Oct 11, 2006 | 07:37 AM
always faster's Avatar
LT4 Valvesprings:Retainer,Locks included and shim adjustement???
Ok with the help of member in my last thread about refreshing my valvetrain, i ve decided to go with these rocker:
Comp pro mag 1.6 SA
http://store.summitracing.com/partde...5&autoview=sku
I know that the rocker comes with the polylocks.
I also want this spring kit:
LT4 valves spring kit
My questions:
Does this spring kit comes with the retainer and locks or i must buy them separetly?
Thank you
Old Oct 11, 2006 | 07:50 AM
Mtrhds94Z's Avatar
Re: Valve springs kit?Retainer and locks included???
No it's just 16 springs..
You need:
LT4 SB Chevy Valve Spring Cap Kit 12495492 [16/ 10212808's]
LT4 SB Chevy Valve Spring Keys Kit 12495503 [32/ 24503856's]
Old Oct 11, 2006 | 07:58 AM
You need:
Thanks a lot
Since you are there ,is the part number for the rocker is the good one?
And do you have by any chnace the part number of the valve seal? I will also changed while im gonna be there.
Thank you again im pretty noob in the vlavetrain
Old Oct 11, 2006 | 02:38 PM
Mtrhds94Z's Avatar
LT4 SB Chevy Valve Spring Shim 10212809
LT4 SB Chevy Valve Stem Seal [intake] 10212810
LT4 SB Chevy Valve Stem Seal[exhaust] 12564852 red
I have the Crane Gold SA rockers so can't help you re the Comps..
Old Oct 12, 2006 | 08:07 AM
Well i was talking about the valve stem seal for the lt1 valve since i got the stock one.
Also i dont need shim because im keepingmy stock cam and also will be reusing my stock spring seat.(correct me if im wrong)
Old Oct 12, 2006 | 04:22 PM
Ok with the help of the search button i ve found that i would need to maybe shim the spring.
So is it a good model:
And even if i have found that i will probably need to shim i still dont understand what to do.I understand how to install the valve spring height...
but what do i do after?
From shoebox sites:
Get the recommended height values for the spring pressure you need from your manufacturer or seller. Use shims if you need them to get the correct height.
Can someone explain?
Old Oct 13, 2006 | 06:58 PM
Still need to know if its the a good model:
Also i need information.Can someone explain me what to do and what number(value) should i get.Im totally lost.
With all my search on ths board i ve understand that i must measure the spring height but...after that i will find out this info what do i do
Thank you
Old Oct 13, 2006 | 11:54 PM
Mtrhds94Z's Avatar
The LT4 springs /retainers/ locks can go on with no fuss.. just put them on as is..
Also, I don't have the LT1 valve seal p/n's ..
You can use the stock LT1 shims/seats, or get the LT4 shims .. I believe they are the same thickness... either one will work OK..
When I did mine, I left the LT1 shim/seats in there, as I didn't need to change the valve seals, so I left the LT1 shims on..
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Don 97 SS
Jul 11, 2005 08:50 AM
