which valve springs
Old Jun 25, 2008 | 09:15 PM
95TALT1's Avatar
which valve springs
CAM: 224/236 .605/.622 with 1.6 SA Pro Mag RR
I broke some piece of sh*t cm 612's. Im wanting to keep stock diameter so I dont have to pull the heads off.
Thanks,
Waylon
Old Jun 25, 2008 | 11:16 PM
Sinister95Z's Avatar
I went with the Comp Cams Beehive 26928-18. Good for up to .650 lift.
Old Jun 26, 2008 | 01:27 PM
seawolf06's Avatar
Get the PAC 1518's. They are good to .650 lift. Make sure you set them up with max pressure for those aggressive lobes, though.
Old Jun 26, 2008 | 05:48 PM
96capricemgr's Avatar
The springs guys are telling you to use will get beat up in just a few thousand miles.
Tht lobe is irresponsibly aggressive for street use and you are going to need even more spring.
wrd1972 battles this recently and has a good thread in the archives from just a few months back, had it "resolved" for now at least but no long term results on the spring he settled on yet.
Do a search, find that thread, it will help.
Old Jun 26, 2008 | 07:08 PM
truedualws6's Avatar
Check your other post. I would say try the Crane 99893 springs and install them at 1.80" (150# closed). At 1.80" installed height the Cranes are good to .650". If they don't hold up then you should consider Manley NexTeks or another equivalent spring. If you still have trouble I'd switch to 1.5:1 rockers.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
