Valve springs
Old Oct 31, 2007 | 09:36 AM
lt1loudmouth07
Guest
Posts: n/a
Valve springs
Is it a bad idea to replace one haeds valve springs instead of both the thing is i am taking off my cylinder head and while i am taking that off i would like to replace the valve springs would it hurt the car if its just one side. and also since i am taking my intake manafold off the car should i get it ported or not?
Old Oct 31, 2007 | 09:54 AM
The Engineer's Avatar
You can do a "heads-on" valve spring replacement on the other side. That would be the best option, to have new springs on both sides.
Crane makes a SBC heads-on valve spring compressor that works well on the 4th Gen F-Body’s where the cowling hangs over the back two cylinders on both sides.
WD
Old Oct 31, 2007 | 09:12 PM
OBE1 95Z28's Avatar
Not going to see any gains on a ported intake without porting the heads or upgrading the cam.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
