Valve spring tools
Old Jul 14, 2008 | 06:27 AM
86formula's Avatar
Valve spring tools
can someone give me a list of tools ill need to do valve springs with the heads on the car. links to websites would help as well. thank you
Old Jul 14, 2008 | 06:56 AM
Pontiac_97's Avatar
the valve spring compressor tool, a regular wrench for adjusting the rockers and for taking off the valve covers. and one of those little magnet pens for dropping in the spring locks. those tiny little things that hold it in place. you dont need the magnet thing it just makes it easier
you can pick up both of those things at autozone in the special tools aisle.
thats all you need.
Old Jul 14, 2008 | 07:17 AM
ZL1modified's Avatar
hop on over to ls1tech and do a search for "tims valve spring tool"...
i used this for my crane 10308-1 vs kit and it worked like a charm...
very good price too i might add...
Old Jul 14, 2008 | 07:58 AM
There are various spring tools to choose from and some work better depending on what spring you are using. Here is a guide from my Tech Page.
Old Jul 14, 2008 | 09:50 AM
86formula's Avatar
thanks guys. they were Comp bee hive springs and theyre getting swapped to Patriot Titaninum dbl Valve Springs with locks, retainers and lockers. which tool would you suggest for them Shoebox?
Old Jul 14, 2008 | 11:26 AM
cehan's Avatar
I used the Crane tool for my CC26918 to PAC1518 swap. Best tool I've ever used for on car replacement. I don't see why it wouldn't work for any SBC spring, beehives or conventional.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
