Valve spring swap, air to the cylinders?
Old Sep 29, 2009 | 02:38 PM
it's allgood's Avatar
I need help.. i dont think i can get my air adpter into all the plug holes due to the pacesetter LT's. What do you guys use to get to all the plug holes? I figure it's easer to ask and alot faster than figuring it out myself. I want to hear this thing run soon. thanks, Curt
Old Sep 29, 2009 | 02:49 PM
dangalla's Avatar
i use a compression tester hose with the air valve removed
Old Sep 29, 2009 | 08:19 PM
Prorac1's Avatar
ditto, worked like a charm
Old Sep 29, 2009 | 08:50 PM
ChevalierSS's Avatar
i just moved each cylinder to top-dead-center; if the valves fall down they don't fall far enough to drop out.
Old Sep 29, 2009 | 09:24 PM
greenmachinedriver's Avatar
i also had this problem when i did my cam swap headders would not let me get the air line to all the cylinders so i just rotated the engine to tdc for that cylinder to keep from having a disaster if i droped a valve. i then used a pen magnet to hold the tip of the valve while i removed the keepers then let the valve sit on the top of the piston while i removed the spring and put the new spring in place. then use the pen magnet to hold the valve all the way up while you replace the keepers.
Old Sep 29, 2009 | 09:44 PM
reamo04's Avatar
what i did as well
Old Sep 29, 2009 | 10:09 PM
Do TDC or TDC with some light rope pushed into the plug hole.
Old Sep 30, 2009 | 10:07 AM
The magnet and the rope will work great. i've used rope before, but the magnet is thinking outside the box. Or outside my little tiny box...............
see why i ask you guys this stuff!!!!!!!
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
