Valve Spring Swap?
Old Mar 9, 2006 | 11:48 AM
94_6speedZ's Avatar
Valve Spring Swap?
I am about to start a cam and valvetrain swap and i was wondering when i should change the valve springs and hardware. Should i change them before i swap the cam, after the cam, with the intake on or off?
Also any suggestions or tips about the process that might help me would be appreciated.
Thanks,
-Greg
Old Mar 9, 2006 | 11:56 AM
MeanGreen97Z's Avatar
Re: Valve Spring Swap?
Anytime.... its all the same. As long as you dont run the motor before you swap them. Bring each cyclider to TDC and chnge the springs for that cylinder. It's easy that way with the heads on.
Old Mar 9, 2006 | 12:08 PM
Javier97Z28's Avatar
Moderator
And pretty much the only way to get it done w/ any type of exhaust connected to the heads. I've yet to find an air fitting that will fit in our engine bays around the exhaust.
Old Mar 9, 2006 | 09:48 PM
There is a valve spring swap "how to" on my Tech Page.
Old Mar 10, 2006 | 07:35 AM
94_6speedZ's Avatar
Yea i know, i've looked over that along with the cam removal and install many times. I just wasnt sure on when to actually change the springs during the whole process.
I will be using the TDC method for changing them.
It looks like i can do it either before or after i change the cam.
Thank you,
-Greg
Old Mar 10, 2006 | 10:28 AM
1quickTA's Avatar
It really doen't matter. You will want to pull the rockers off before the cam install/removal so that you can take out the pushrods and lifters, but the springs really dont matter. Follow the guide on shoebox's site and you will be fine. Also, make sure to follow his tip about using a small socket to "shock" the locks loose before compressing the springs. That really helped.
DirtyDaveW
Mar 15, 2015 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
