Valve Spring Questions
Old Aug 16, 2005 | 09:11 PM
snod83's Avatar
Alright, here is the cam that I have:
Duration Lift w/ 1.6 rr LSA
218 0.528 0.537 112
I was wondering what spring I should use, I have been thinking about the following options:
Crane cams 10308 kit with 99893 dual springs
Comp cams 983-16 springs with stock retainers/locks
Comp cams 26918 springs with stock retainers/locks
Any opinions are welcomed. I am looking to use as many stock parts as possible, such as the retainers and locks (not sure if possible) and I was also hoping to spend as little cash as possible! (haha, not gonna happen). I do not want to cut the spring pockets....
Thanks for your help,
Ryan
Old Aug 16, 2005 | 09:18 PM
rskrause's Avatar
Moderator
Re: Valve Spring Questions
The cam manufacturer is the best source for this info. Why are you using a single pattern cam in an LTx motor, just curious.
Rich
Old Aug 16, 2005 | 10:53 PM
snod83's Avatar
Sorry I made a mistake,
Duration is 218/224
Lift with 1.6s 0.528/0.537
112 LSA
I appologize, I am a horrible typer!
Thanks.
Ryan
Old Aug 17, 2005 | 10:27 AM
1racerdude's Avatar
Whatever springs ya get get retainers and locks too. I didn't and it cost an engine.
Call the cam maker for recommendations on springs.
Old Aug 17, 2005 | 10:50 AM
BUBBA's Avatar
10308 kit. JMHO
Old Aug 17, 2005 | 01:24 PM
SStrokerAce's Avatar
26918's are the best choice.
Bret
Old Aug 17, 2005 | 02:27 PM
96capricemgr's Avatar
You need to do some more research as those wont work with stock retainers and while stock locks might work I would think a set of +.050s would be better. I agree with Bret that they are the right springs for the job, you just can't use them with the parts you wanted to.
Old Aug 17, 2005 | 02:36 PM
JustNO's Avatar
I can't understand.. We can use 26918 for a smallest cam to a big cam.. Its very usable.. What is the end limit specs for 26918??
Old Aug 17, 2005 | 03:22 PM
depends on the RPM and lobe profile. If you get the 26918's get retainers and locks to go with them.
Bret
Old Aug 17, 2005 | 03:36 PM
JustNO's Avatar
What is the part number of titanium retainer for 26918? Everyone says different thing..
Old Aug 17, 2005 | 04:04 PM
BUBBA's Avatar
Unless you plan on spinning 7 grand, you might want to spend your loot on something other than titanium retainers. JMHO
Old Aug 17, 2005 | 04:21 PM
One of the key benifits of beehives is the smaller and therefore lighter retainer being smaller a switch to titanium will net you a whole lot less weight savings than it would with traditional springs and retainers, by the time they become a remotely good idea I would think a rev kit would be a better way to spend that money.
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
