Valve spring questions
Old Feb 12, 2004 | 10:43 AM
1BadBrd's Avatar
Im going with the GM 847 234/242 .575/.595 112 and what spring should i use?
Options:
Springs-:
-K motion- KMO K-800
-CC 987-16
-CC 893-16
I don't know which is dual spring max lift or will they fit without machining.
Retainers:
-CC730-16
Keepers:
-CC611-16
Someone mentioned spring seats. But i do not know what that is, but the part # is CC4784-16
Can you help me understand better! Make sure i get the best set for my set up.
Atljar: I know you have helped but are the springs the best option? Also did you have to use spring seats. tracey is telling me that i need them.
Here is what i was told to get
Valve Springs K-Motion K-800
Retainers-Titanium Comp Cams 730-16
Keepers Comp Cams 611-16
Spring Seats Comp Cams 4784-16
Valve Seals GM ?
Old Feb 12, 2004 | 02:52 PM
Brettinator's Avatar
This cam Lift is .539/.558 w/1.5 RRs, .575/.595 w/ 1.6 RRs
Per the Crane spec card it calls for Crane Springs # 99846 but Crane recommended to me the Crane 99893 Spring kit PN# 10308-1 which has a 130lb seat pressure and .710 max lift because I was going to 1.6 or 1.7 RRs.
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
