Valve spring question 977-16
Old Jun 1, 2006 | 06:42 PM
  #16
OldSStroker's Avatar
Re: Valve spring question 977-16
Originally Posted by A/G
Edit: As I had started B4, but finished this post after above post, I'll add the periodic 'double team' amuses me. Yes, it took that long with care and thot, to type this post.
A/G, you may have noticed that Bret doesn't need help or 'double teaming' from me.
Did you miss my question above, or would that be prying?
Old Jun 2, 2006 | 07:26 PM
  #17
SStrokerAce's Avatar
Actually it might explain a lot about you.
Bret
Old Jun 3, 2006 | 08:55 AM
  #18
roughneck427's Avatar
Is that what you call it? I'll give roughneck a couple more days B4 I follow thru. I inclined to believe he's read my request to respond. Is he that intimidated? BTW, you had your chance to post what I intend to, Mr cam/spring guru. .... Patience!
Wow havent been on here a few days lots of OT kinda blew into a pissing match.Thanks for your guys opinions everyone has them.All i was doing was trying to match springs for a GM 847 cam.The guy that ports my heads is a CC dealer and yes like Gary said the price lures people.All i needed was honest educated opionions and maybe i should have posted it up SStrokerAce knows the specs on the springs and Gary they are 441lbs/inch spring rate all i wanted to know is send them back or now i already have titanium retainers that i cant send back if you guys think this spring will work for my setup also i will only be using 1.5 ratio rocker arms not 1.65 like i had in my sig.Thanks guys!!!
oldschool
Feb 9, 2016 09:21 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
