Valve spring question.
Old Mar 21, 2007 | 07:09 PM
henryz28's Avatar
I just sold the springs that came with my lt4 hotcam kit.And I want to buy better ones, what springs should I get?I do not want to do any mods to my heads I want springs that will work with no other mods.thanks
Old Mar 21, 2007 | 07:15 PM
ZL1modified's Avatar
why didn't you use your lt4 springs? theye are more than enough for that cam...
Old Mar 21, 2007 | 07:29 PM
henryz28's Avatar
I was told that they arn't that good; I was told that they are barly good enough for that cam and the 1.6 rrs.I want somthing that will be more than good enough.
Old Mar 21, 2007 | 08:19 PM
henryz28's Avatar
I think the max lift on the lt4 springs is .525 and the hotcam lift is .525 without the 1.6rrs.
Old Mar 21, 2007 | 08:23 PM
lt4 spring example: if your install hieght is 1.78" and coil bind is 1.085"... that leaves you with 0.695" of lift... then you have to deduct 0.060" of lift for your green zone(which is the recommended distance from coil bind) which leaves you with .635" of lift with 1.5 rocker arms... now if you have 1.6 rockers then you must subtract an additional 0.034" from your lift... which would then leave you with 0.601" of lift...
and your cam has 0.525" of lift which would give you 0.076" of safety...
more than enough...
check my work guys, i think i got everything...
Old Mar 21, 2007 | 08:26 PM
a stock lt4 cam is 0.467" lift on the intake
and 0.480" lift on the exhaust...
depending on what kind of money you want to spend and if you are going to install a bigger cam in the future has alot to do with the decision you will make...
if its money then i would get the lt4 springs...
if you are going to go bigger some day i would go with those 26918 beehive springs from comp...
Old Mar 21, 2007 | 10:31 PM
henryz28's Avatar
I think I am going to go with the comp beehive springs;never know if I want to go with a bigger cam latter on and they are a lot stronger spring.
Old Mar 21, 2007 | 11:11 PM
truedualws6's Avatar
Other options to beehives
Although I have the 26918s installed, I did seriously consider the
Isky 235-D springs first. If you want to save $$ the Iskys will do
the job with all the stock hardware. You can do a search for more
info.
Old Mar 22, 2007 | 09:04 AM
Z-RATED94's Avatar
Then get the beehives, more than enough spring. Plus you can use them down the road if you change cams. If they won't work with your next cam, then all I can say is, "damn that's a big cam".
Old Mar 22, 2007 | 05:30 PM
henryz28's Avatar
info.
Are you saying that if I get the Iskys I will not need anything else but the springs.I can just reuse my stock hardware.
Old Mar 22, 2007 | 06:13 PM
how high do you plan to rev?
i don't think the stock hardware is meant for a high rev definently not with springs with high seat pressure... i.e. 6000 and up
Old Mar 22, 2007 | 06:50 PM
henryz28's Avatar
I really don't plan on reving it pass 6000.
Old Mar 22, 2007 | 07:19 PM
seawolf06's Avatar
You can get the 26918 springs as said before and I'd recommend those if you can afford them. Make sure they'll work with the self-aligning rockers that come with that kit and get the +.050" hardware for the LT1 heads.
There is a nice kit from Crane that should work with that cam and plenty of others as well and it's cheaper. The main benefit to the 918's are that they're a much lighter spring.
Old Mar 22, 2007 | 08:05 PM
if you go big in the future you will almost have to rev high to get all the benifits of the cam... ditch the stock hardware...
Old Mar 23, 2007 | 12:31 AM
henryz28's Avatar
Ya I am just going to cough up the extra cash for the beehives.Thanks
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
