valve spring question
Old Dec 28, 2006 | 02:29 AM
CamaroZ2869C's Avatar
does anyone know the max lift from a cam that stock valve springs can handle on a 95 lt-1
Old Dec 28, 2006 | 03:28 AM
MachinistOne's Avatar
You need to replace the springs no matter what lift the cam you choose has. The stock spring pressures are not enough to control a performance cam, and with 105k miles, yours are due to be changed anyways.
Decide on a cam, then we can tell you what springs you need.
Old Dec 28, 2006 | 06:33 AM
rskrause's Avatar
Moderator
Ditto.
Rich
Old Dec 28, 2006 | 01:40 PM
T/A-Bob's Avatar
The max safe lift = Installed height - coil bind height - desired clearance.
For the stock LT1 springs, that equals 1.780 - 1.260 - 0.060 = 0.460.
Since the exhaust lift of a stock LT1 is 0.460 (a tiny bit different for some of the years), you can see why stock springs need to be replaced for a bigger cam. GM matched the stock stuff pretty carefully.
Old Dec 28, 2006 | 01:41 PM
thanks for the info
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
