Valve Spring Question
Old Feb 27, 2006 | 04:29 PM
cmaell2's Avatar
Sorry to post another valve spring question, I have tried to search but havent found what I am looking for.
I am looking for a spring that will fit my stock LT1 alum heads and be good for either
Hot Cam(218/228) / .525/.525 or
cc503 cam (224/230) / .536/.544
The hot cam kit comes with marginal springs, comp recomends 986 springs, but those require machineing...
I was looking at comp 918's or the 99893 springs by Crane.
The 99893 springs are significantly cheaper than the 918's, and I think I can use stock retainers with them?
Will one of these springs work for my application, both of them, and to use um what else do I need to buy? I know stuff like Ti retainers would be worthwhile in really perf. oriented engines, but mine is a daliy driver and will probably never see over 5600 or 5800 rpm.
Chris
Old Feb 27, 2006 | 04:31 PM
shannons86's Avatar
Re: Valve Spring Question
Look at comps 941-16. Might work for you application.
Old Feb 27, 2006 | 04:41 PM
Silvershark's Avatar
I would go with Beehive springs.
Old Feb 28, 2006 | 08:06 AM
cmaell2's Avatar
What is the problem with the crane 99893 springs? Does comp make better springs or something?
If anyone knows if these springs will work would greatly help me.
This is the link to the product description.
http://www.cranecams.com/index.php?s...&lvl=3&prt=123
Thanks,
Chris
Old Feb 28, 2006 | 12:36 PM
They will work. However, if you decide down the road to go with a cam that's bigger you will need different springs. Those also show they are for a BBC.
Old Feb 28, 2006 | 12:41 PM
97bowtie's Avatar
Take a look at the Crane 10308 springs. They are ideal for either cam.
Old Feb 28, 2006 | 02:57 PM
cmaell2's Avatar
The 10308 kit has the 99893 springs, so I guess that will work,
Thanks guys
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
