Meziere water pump.....
Old Feb 28, 2006 | 02:34 PM
playa7970's Avatar
Im about to purchase one of these does anyone know what else im going to need with this such as harness and also what can i plug the gear hole with? and do i have to replace the actual water pump
Old Feb 28, 2006 | 02:46 PM
Harvey's Avatar
Thumbs up Re: Meziere water pump.....
Meziere sells a wiring harness you can buy for like $30. I just bought some extra wire of the same gauge as the harness and some splice connectors and went to town. This harness comes with the relay and inline fuse. Very nice set-up if you ask me. It's a Bosh realy and I found this website on line that listed how to hook up the wiring. For the switch on the relay, I used the fan switch in the relay box under the hood. On mine the wire was orange.
You defintley have to remove the stock water pump. As far as the gear hole, I bought the pump used and already mounted on the housing ready to go, so I didn't have to deal with all that. I believe people just use a frezze plug. Not sure what size. Hope this helps some.
Old Feb 28, 2006 | 03:04 PM
izzyz28's Avatar
The pump comes with a brass freeze plug. To install it you'll ned to remove the impeller and shaft. A press works great and I imagine a punch and a hammer would work too. Make sure you press the shaft out of the BACK of the pump(press from the front or impeller side), as it'll only come out one way.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Sep 27, 2015 01:07 PM
