Valve spring question.....
Old Apr 7, 2003 | 08:45 AM
1997TransAm's Avatar
Exclamation Valve spring question.....
I've decided to go with the xe224/230 cam. should I be okay if I buy springs that are rated up to .550'' lift. will that be sufficient?
I will be using 1.6rr's.
here are the stats for the springs...
Spring Pressure Installed: 115# @ 1.700" -- 110# @ 1.800"
Spring Pressure Open: 335# @ 1.200 -- 325# @ 1.250
Coil bind @ 1.150"
Thanks!
Old Apr 7, 2003 | 10:21 AM
If your cam has .510 lift on the exhaust side with 1.5 rockers, then it will have .544 with 1.6. That cuts it a little close.
Combination Motorsports has a set of springs that will go right on without modification and are good to .600 lift. They are not expensive. Nice folks to deal with, give them a call and ask any questions you like.
Old Apr 7, 2003 | 04:11 PM
any other opinions?
Old Apr 7, 2003 | 04:22 PM
TobyZ28's Avatar
I'll second that just because shoebox sez so.. and not because I have no clue as to what your talking about
Old Apr 7, 2003 | 04:26 PM
turbo_Z's Avatar
combination motorsports has a spring kit good to .600" lift for only $90.
Old Apr 7, 2003 | 04:35 PM
LOL!
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
