valve spring problem
Old Aug 9, 2004 | 07:19 PM
25th_Trans's Avatar
Here's the problem, one of my valve springs broke. I have the LT4 Hotcam, 1.6rr, LT4 valve springs, and trick flow chrome moly pushrods 7.200 .080.
I was told that the LT4 valve springs would work with this setup, but that was before I got the pushrods. Could that be the reason that they snaped or is it most likely just a defective spring?
I was lucky enough that the valve didn't drop thanks to new valve stem seals, so I would like to know before I replace the spring. If you need to see a pic of the spring let me know.
Old Aug 10, 2004 | 06:31 AM
25th_Trans's Avatar
Re: valve spring problem
don't really know much about this. Would appreciate the help.
Old Aug 10, 2004 | 07:47 AM
Ai's Avatar
Ai
That could be an issue with the spring, or with how it was installed. I would check the installed height where it broke and see what sort of coil bind clearance you were running with & go from there personally
-Phil
Old Aug 10, 2004 | 09:26 AM
25th_Trans's Avatar
what problems would I see if the pushrods were too long? Would that cause a spring to break?
Old Aug 10, 2004 | 10:38 AM
Compstall's Avatar
That could cause coil bind, which would/could break the spring.
Old Aug 10, 2004 | 12:59 PM
Mindgame's Avatar
When you checked the springs the first time around.... what was the clearance at max lift?
-Mindgame
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
