Sort of rough start
Old Aug 10, 2004 | 12:08 PM
vin1382's Avatar
Sort of rough start
I have a 93 lt1 with minimal mods(just intake and exhaust), and when i start it up, it seems to start rough a bit. after a few seconds, it runs just fine. i have another lt1,(96), and it doesnt do this.
The rough start, you can hear the engine firing, but it doesnt just fire up completely, if you know what i mean. after a few seconds, it seems to find the idle,and then it starts chugging like it should. What things should i look for?
Old Aug 10, 2004 | 12:44 PM
25th_Trans's Avatar
Re: Sort of rough start
Mine did the same thing when I bought it. I later found out when I installed the cam that one of the wires going to the coil broke. The bolt that holds the coil on the head has 3 washers between it, one of mine broke off the washer. After I replaced it the problem went away.
Old Aug 10, 2004 | 01:32 PM
n2ceptor's Avatar
IAC(idle air control valve) that was my problem....
armedtrigger
Feb 24, 2015 08:30 PM
Iamherefornow
Jan 26, 2015 04:57 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
