Valve Spring Lift
Old Sep 19, 2004 | 02:16 AM
Speedfreak19's Avatar
Valve Spring Lift
What lift are these springs good up to?
EX Components 612 Single Coil Extreme Performance Valve Spring
Also ill be runnging LT4 Hot Cam,1.6rockers,Ported Heads and Intake etc..what size valves would be the best to run? 2.0,1.6? or 2.02,1.6
Old Sep 19, 2004 | 02:30 AM
simple's Avatar
Re: Valve Spring Lift
not sure about the springs but the larger combo of valves you listed will require the valve seats to be machined. you can use the smaller set (2.00/1.56) on a stock seat just fine
2.00/1.56 is a good sized valve combo specially for what you are aiming for imo might even be a bit much
Old Sep 19, 2004 | 04:11 AM
Well my heads are in the shop getting machined so it isn't a big deal. Can someone help me out on the springs? But does anyone else think 2.0 and 1.6 valves are good for my setup?
Old Sep 19, 2004 | 05:07 AM
Z-RATED94's Avatar
2.00/1.56 would be fine with the Hot Cam as Simple said. No pun intended!
Old Sep 19, 2004 | 11:36 AM
Ok well can someone tell me what lift those springs up there are good up to?
Old Sep 19, 2004 | 11:43 AM
RamAir95TA's Avatar
Up to .600".
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
