Which valve spring kit
Old Aug 4, 2008 | 08:08 PM
Leem927's Avatar
Which vlave spring kit would i need to purchase for the TN227XR cam that is going to go right on the stock head with no problems? I also plan on getting 1.6rr Which should I go with the Self aligning or the non self aligning? thanks for any help.
Old Aug 4, 2008 | 08:23 PM
seawolf06's Avatar
The only "kit" I know about is Crane 10308-16, but you'll have to give all the cam specs for someone to make an educated suggestion.
Old Aug 4, 2008 | 08:54 PM
Leem927's Avatar
sorry
Combination Motorsports Comp Cams TN227XR Camshaft
Grind # LT1 3441 / 3442 HR114+4
Serial No B 0452
Part # 07-000-8
Intake Exhaust
Gross valve lift .525 .534
.560 .569 with 1.6 RR's
Duration @ .006
tappet lift 277 283
These specs are for cam installed at 110.0 intake center line
Intake Exhaust
Duration @ .050 227 233
Lobe Lift .3500 .3560
Lobe Seperation 114.0
Old Aug 4, 2008 | 08:59 PM
seawolf06's Avatar
Then the Crane kit will work nicely.
Old Nov 17, 2008 | 10:07 AM
ss.slp.ls1's Avatar
Will it also work nicely for a CC503? What spring locators (seats) are required? Anyone know the part number for the seats or the correct valve seals by any chance? Thanks for the help fellas.
Old Nov 17, 2008 | 10:09 AM
seawolf06's Avatar
Valve seals are determined by the valves, not the springs. Any engine shop should be able to get those for you.
I believe the Crane kit is meant to work with stock seats.
Old Nov 17, 2008 | 10:23 AM
ss.slp.ls1's Avatar
Stock valves. Thanks for the answer about the seats.
Old Nov 18, 2008 | 04:35 PM
ss.slp.ls1's Avatar
Wait, what about clearance issues with dual springs? I want to know if stock valve seals will clear under the Crane dual spring kit?
Old Nov 18, 2008 | 08:12 PM
seawolf06's Avatar
I've never used these, but I would think that Crane thought of that.
Old Nov 19, 2008 | 11:40 AM
69z-28's Avatar
it can be a drop in kit. there is no need for anything else at all.
stock valve seals will clear. if you got higher mileage go to your local autoparts store and get new ones. i never had a problem with the crane dual springs in the 10308 kit and the valve seals i got from autozone. they should be able to find the seals through the computer at the store. otherwise i think i looked them up on shoeboxes site a WHILE ago. can't remember.
Old Nov 19, 2008 | 11:42 AM
ss.slp.ls1's Avatar
Thanks. I went ahead and ordered felpro replacements.
oldschool
Feb 9, 2016 09:21 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Dec 1, 2014 08:08 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Don 97 SS
Jul 11, 2005 08:50 AM
