Valve spring install height problem,please help !
Old Jul 4, 2007 | 11:47 AM
  #16
speed_demon24's Avatar
Originally Posted by 94heritageZ
Thank you for the help. Would a safe install height be between 1.765 to 1.800???
Are you sure the step is .150 down? Bret told me his was .150" down on his, but I measured mine and it was .130" down so if its a comp one I would have it checked just to be safe. And what cam are you running?
Old Jul 4, 2007 | 12:00 PM
  #17
6SpeedIROC's Avatar
For the PAC 1218 springs on LE2 heads and LE2.2 cam from early 2007, I was told by Lloyd Elliott to use an installed height of 1.750 to 1.760 for the 'springs to last' even though this is different from what comp has in the catalogue. Catalogue height is 1.800 as you have noted...
Old Jul 4, 2007 | 01:17 PM
  #18
Yeahdoug's Avatar
Depends on the lift too. Either way both springs should have no problems being installed at 1.800" But if your running a lower lift cam. Say around .600 to .620 lift you can install it around 1.750. I know for some people installing them at 1.800" doesn't give them enough seat load so they'll install them at 1.750"
I think I might have the springs compressor mixed up. The screw compressor I'm thinkin of is from Buxton Engineering. I'm not familiar with the KD one. You always want to use one that presses down on the retainer.
Old Jul 4, 2007 | 02:10 PM
  #19
The Engineer's Avatar
The lever type spring compressors work great on the front four cylinders, however, the back four (#5, 6, 7 & 8) under the F-Body windshield cowling you can't use the lever type.
WD
Old Jul 4, 2007 | 03:07 PM
  #20
WD
The crane one works on all cylinders on the car, it does 2 springs at a time too.
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
