valve spring help already did search
Old Feb 9, 2005 | 08:30 PM
cammed_aro Z28's Avatar
Question valve spring help already did search
i already did a search so please be nice, i am looking for the best valve springs for my cam, i have the comp XE 224/230 it has .503 .510 lift and stock rockers, (1.6 coming soon) are the comp springs that my cam card recommend probably the best or is there a more cost effective (read cheaper)set out there. part #'s and price would be appreciated
thanks
steve
Old Feb 9, 2005 | 08:44 PM
truedualws6's Avatar
Re: valve spring help already did search
Options include Isky 235-D, Comp 26918, Crane 99893 (or the 10308-1 kit),
CM kits, K-motions, Manleys, etc. You need to decide what you want to spend
and then see where you stand. The 235-Ds are about $100, 26918s are $150,
the kits are more but also include retainers and locks. This is also assuming that
you are talking about stock aluminum heads.
If you decide to go with the Isky springs I have a NIB set of Comp titanium
retainers that are available, and a set of super locks. The retainers will work
with most single spring setups.
Old Feb 9, 2005 | 09:19 PM
is the crane 10308-1 kit a significant upgrade from stock? somebody told me stiffer valve springs will give me significant power increase, i know i am pushing the limits with my stock springs.
thanks again
Old Feb 9, 2005 | 09:30 PM
cat1055man's Avatar
I would use the springs that the cam manufacturer recommends. If you must go with a different brand the match the specifiations of the recommended spring.
Old Feb 9, 2005 | 10:08 PM
Daryn95Z's Avatar
Ran that same cam for a while with the CM 612's, I think comp makes them. Give combination motorsports a call, that's where I got mine.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
