Valve Spring help
Old Jun 29, 2005 | 03:18 PM
fade2blk500's Avatar
Valve Spring help
What are some good valve springs that will hold up to a gm847 with 1.6 rockers?
Lift being in the mid 590's and duration 234/242 I do believe. Also is any machining/shimming required? If so please post up.
Thanks!!
Craig
Old Jun 29, 2005 | 04:05 PM
BUBBA's Avatar
Re: Valve Spring help
Cam Card should give you required spring specs. Whoever provides that cam should provide recommended spring including ID and OD of the spring. There should be a spring available that will fit your stock seats and no machining will be necessary. Do some checking. JMHO
Old Jun 29, 2005 | 04:20 PM
BUBBA's Avatar
You might consider the Crane Dual Valve Spring PN 99893-16
OD: 1.460
ID 1.075
Seat Pressure: 130 lbs @ 1.850 install ht.
Open Pressure: 402 lbs @ 1.150 install ht.
Coil Bind 1.080
avg. spring rate: 391 lbs/in
I believe that the stock seat should fit (maybe snug, but should be ok)
Old Jun 29, 2005 | 04:41 PM
BUBBA's Avatar
Now that I think about it: I believe that is the same spring recommended for my little 210/224 cam and it apparently fits. It's basically for a big block or RV cam. Should work fine. Good luck.
Old Jun 29, 2005 | 08:45 PM
MachinistOne's Avatar
402 # is way to high for an hydraulic roller cam.....
You need a spring that will be 120-130# seat/ 300-315 at max lift.
Old Jun 29, 2005 | 09:13 PM
Compstall's Avatar
K-Motion K800's.
Old Jun 29, 2005 | 10:46 PM
WS6T3RROR's Avatar
machinist, also note thats at .700" lift before you get too excited.
Old Jun 30, 2005 | 03:52 AM
Alright I've decided those crane duals look pretty good. Fairly good price and they fit with stock seats. How about retainers/locks? Are the stock ones capable of being used or should I go with aftermarket retainers/locks? Thanks alot guys for the help.
Craig
Old Jun 30, 2005 | 09:49 AM
BUBBA's Avatar
Get the stuff that goes with the springs. JMHO
Old Jun 30, 2005 | 10:13 AM
BUBBA's Avatar
Consider getting the kit which contains the springs, retainers, keepers, shims. PN 10308-1
Old Jun 30, 2005 | 04:30 PM
Thanks alot for the help I'm going to order that within the next week
Old Jul 1, 2005 | 01:07 AM
LOL - I didn't notice that...but even so the spring rate would put the open pressure at 345# at .550
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
