Valve spring
Old Feb 16, 2008 | 09:24 AM
williamfvc's Avatar
Valve spring
Can i use these spring in a 94z28 5.7L? with a RR 1.6 ratio?
http://cgi.ebay.com/ebaymotors/SBC-C...2869QQtcZphoto
or these ones
http://cgi.ebay.com/ebaymotors/SBC-C...9348QQtcZphoto
Old Feb 16, 2008 | 09:43 AM
red94chicken's Avatar
those are hydraulic flat tappet springs. not roller.. they would work but i think it might float at higher rpm
This single valve spring is use on LT1 Production Corvettes. Small Image Technical Notes: Single spring with 1.30" O.D. and 1.26" solid height. The pressure at installed height is 85# @ 1.78" with 373# the average rate of pounds per inch. Use with retainer P/N 1016842
those are only 320 and 360 at full lift and lt1 springs suck for revving so do the math
Old Feb 16, 2008 | 11:22 AM
2000GTP's Avatar
Just pick up some LT4 springs for 35-40 bucks and call it a day.
Old Feb 16, 2008 | 11:33 AM
williamfvc's Avatar
Thanks guys. where can i buy LT4 springs?
Can i use the factory retainers?
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
