valve lash adjustment
Old Jun 17, 2005 | 12:44 PM
BLAKBIRD's Avatar
whats the thickness of the feeler guage that I need to use when adjusting the lash on an LT-1? Im all ears! thanks guys,
Adam.
Old Jun 17, 2005 | 12:59 PM
Re: valve lash adjustment
They are hydraulic rollers, you don't use a feeler gauge.
Various ways to set the lash.
Old Jun 17, 2005 | 01:18 PM
MaxLean's Avatar
Well, assuming that you have a hydraluic roller, you don't use a feeler gauge. Verify that the particular valve you're going to adjust is on the heal of the cam, set to zero lash, and the apply the amount of preload that you want, usually between 1/4 turn past zero to 3/4 turn.
Old Jun 22, 2005 | 12:01 PM
BLAKBIRD's Avatar
well see what I did was take the rockers off... I was taking those off as well as the head bolts becuase I was about to change the springs and do 1.6rr's but I never got the rockers and I decided not to do the springs either, so now they make all sorts of noise.....ttt
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
FredM
Apr 10, 2015 02:56 PM
