Valve Lash
Old Jul 15, 2004 | 01:53 PM
disco192's Avatar
Valve Lash
Can you miss zero lash by adjusting it by hand (no wrench)? Im using comp pro mags and they bolts are really smooth, unlike stock rocker bolts. Im curious if i can go past zero lash by hand. How definate is zero lash? I have comp pro mag lifters if that helps.
Old Jul 15, 2004 | 01:55 PM
roadrage912's Avatar
try spinning the pushrod. or you could move it up and down to see if there is any slack, i dunno how u would be able to tell right by just tightening the bolt and trying to guess.
Old Jul 15, 2004 | 03:46 PM
Revolutionary's Avatar
If you have new lifters or if your lifters have bled down then yes you can go past zero lash easily by hand. It is too easy to go past zero lash by the 'spinning pushrod' technique IMO so I always wiggle the pushrod up and down while tightening it until it just stops wiggling up and down and call that zero lash.
Old Jul 15, 2004 | 03:49 PM
we did pretty well with it, i just actually did it for the first time a few weeks ago. mostly it was an ex mechanic but i learned a lot. haven't had any problems yet either.
Old Jul 15, 2004 | 05:16 PM
Gangly's Avatar
just put a white mark on all the rocker nuts. once you think the slack in the pushrod is lost, tighten the nut an 1/8 of a turn by watching the white mark on the nut.
Old Jul 15, 2004 | 05:18 PM
Dave89IROC's Avatar
1/8 turn is likely too far with comp r's................
Old Jul 15, 2004 | 07:24 PM
96WhiteZ28's Avatar
I have stock lifters. They say adjust from 1/2 to 1 turn past zero lash. That seems like a big difference. Should i stay at 1/2 or go towards 1 turn?
Old Jul 15, 2004 | 09:06 PM
Dave89IROC's Avatar
on new stock lifters I go 1/2 turn past zero
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
