Valve on H2O pump to heater core?
Old Oct 24, 2003 | 04:52 PM
kgkern01's Avatar
I am replacing the small hose from the water pump to the heater hose and there is a small black plastic piece that connects the hose from the heater core to the water pump about 5 inches from the water pump, mine broke. Can I simply use a heater hose coupling to connect these 2 hoses back together, or is that 'valve' absolutely necessary? Am working on it right now, so quick response from anyone who knows this is greatly appreciated?
Old Oct 24, 2003 | 05:46 PM
slopokrodrigez's Avatar
that is a restrictor. If you were to look thru an unbroken one, you would see that it is about 1/2 the hose opening. It isn't a valve. This is to be sure you have more flow through the engine instead of the heater core. Most cars eventually leak at those crimped on connections at that restrictor. When my car developed the usual heater failure I noticed that was leaking. I cut the hoses off and replaced them and put hose clamps on the restrictor. I did run without it in place for a couple of weeks (and boy does the heater get hot when you do) but it's best to put it back in place. I think if you buy a new one, it will have both hoses already crimped on to it.
Old Oct 24, 2003 | 08:46 PM
kgkern01's Avatar
The piece is broke on mine, I simply replaced it with a coupler for the lines. So the only side effect is that the heater will get even hotter with out that restricter? There are no other negative side effects are there?
Old Oct 24, 2003 | 09:36 PM
anasazi's Avatar
i've been running without it for months now, no side affects at all. engine temperatures havn't changed one bit, and i live in hotter-than-hell florida.
Old Oct 24, 2003 | 10:03 PM
Cmr0z28's Avatar
mine broke too a few months ago....a temporary fix was fine but I replaced it for the hell of it a few weeks later....
alex5366
Mar 8, 2015 11:32 AM
kksi
Feb 17, 2015 10:41 PM
Britbilly
Jan 7, 2015 08:49 PM
Black93lt1
Nov 21, 2014 07:30 PM
Timberwolf
Aug 9, 2002 11:24 AM
