Valve float
Old May 13, 2006 | 11:09 AM
Honda Hunter's Avatar
Valve float
How do you know when youre getting valve float?
Old May 13, 2006 | 12:25 PM
SStrokerAce's Avatar
Re: Valve float
The power drops off above a certain RPM and the motor doesn't want to spin any higher... it's easier for me to tell on a dyno than anything.
Bret
Old May 13, 2006 | 12:31 PM
Re: Valve float
Oh, ok. I'm way off. I'm trying to figure out why my car feels so weak up top. I guess I can rule out valve float because thing has no problem spinning to the top it just feels horribly weak.
Old May 13, 2006 | 12:44 PM
Re: Valve float
It could be ignition related... the good ole optispark.
Old May 13, 2006 | 01:07 PM
Re: Valve float
I have a Dynaspark. Sometimes I get a high reso code but it goes away. Happened twice but didnt effect the drivability and only happened around start up. Wouldnt even know it popped if I didnt have a scanmaster. Plug are brand new and the wire have 1000 miles if that. Another issue I noticed up top was a cloud of smoke whenever I floor it and along with that cloud of smokes sometimes I have flames shoot out. Something is going on but I can put my finger on it.
Old May 13, 2006 | 01:24 PM
Re: Valve float
Yeah something is wrong if you have flames and pig rich cloud of smoke...
I gotta think about that one.
Bret
Old May 13, 2006 | 01:26 PM
Re: Valve float
I plan on getting dynotuned soon but first I wanted to make sure everything mechanical is sound. It is running pretty rich at wot. around the 10's a/f I believe.
Old May 13, 2006 | 01:27 PM
Re: Valve float
Yeah that's not good
Old May 14, 2006 | 07:46 AM
526 SS 96's Avatar
Re: Valve float
I saw on your car domain page that you changed out the fuel injectors. If the car has no tuning and you changed to a larger injector, then that's your problem. When I got my AI cam & head package I had to upgrade the injectors. The car had a hot cam tune in it before (used factory injectors), so I thought to just install my 42's and drive to the dyno to get it sorted out. Dude, the car barely made it to the dyno. Frequent stalling, rough idle, won't rev, black smoke ect... After a couple of minutes on the dyno my tuning guy straightened it all out and the car drove home perfect. So give that a shot, or just put your stock injectors back in to see if it clears at all. Don't race with the stock injectors (might go too lean), but just for testing & normal driving to the dyno you should be fine.
Lastly, make sure to change your oil very soon. All that extra fuel will thin out your oil and might hurt the bearings. That would really suck, but that kind of stuff can happen.
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
